This is an archive of posts from April 8 - 15, 2007 on the Guru's Den
Hey all quick question for whoever can answer. I just finished building a new forge today, a nice forced air one, from a 16" long 8" diameter pipe, and my question now is, how concerned should I be with using it indoors. (inside my 2 car garage, with both doors open that is, like I normally work)
My old whisper baby venturi forge I could practically sit stuff ontop of hte forge and not worry about the heat around it, but this new one is a LOT more powerful and hotter, and i can singe my eyebrows off just standing too close to the front of it. I'm concerned because my garage, while having a nice high roof, is all wood. Should I now be looking at building some sort of metal hood and chimney or something?
http://www.tharkis.com/images/forge.jpg
   Jmercier - Saturday, 04/07/07 22:58:29 EDT
Jmercier, It depends strictly on ventilation, space and distance. I suspect there it relatively low overhead clearance. I would cover the immediate overhead space with dry wall as it is an insulating fireproofing. This will help disapate the hot exhaust so it is not heating one localized area. But you will need doors and windows open and a roof peak vent would help a lot to keep temperatures down.
The fire code will call for triple wall pipe and a proper roof penetration flange as well as the device not being any closer than 30" from anything.
The singing problem can be taken care of with and air curtain.
   - guru - Sunday, 04/08/07 00:39:28 EDT
Small projects: Craig, there are numerous projects on our iForge page. RR-rail anvils are pretty light and thus small work is the rule. Hooks from 1/4" bar, steels for flint and steel made from 1/4 diameter coil spring wire, small knives from small steel. . . miniature anything.
   - guru - Sunday, 04/08/07 00:43:19 EDT
Acids and disposal: If you are environmentally concious then even common mild acids like vinegar become a serious hazardous waste when you use it to disolve cadmium, lead, zinc. . . any heavy metal. THEN you have partially killed acid solution with heavy metals in solution. Where ever you dump this the heavy metals will become part of the ground water and the earth. . .
   - guru - Sunday, 04/08/07 00:52:00 EDT
Muriaic acid with zinc dissolved in it makes a pretty fair flux for soft soldering on galvanized (or bare) steel. It is pretty much what most of the acid-type soldering fluxes are.
There is only one correct way to dispose of contaminatd acid: call youor local hazardous waste removal company and pay the fee. Not cheap, either. If you have a medium-sized business that disposes of the same sort of waste, they MAY be willing to take yours and include it with theirs for a lower fee than the waste handlers would charge. It doesn't hurt to ask.
   vicopper - Sunday, 04/08/07 02:27:59 EDT
Just an update on my new 7" x 12" metal bandsaw. Great. However it is a bit like only having a 12" pipe wrench when all you really need is a 1/2" open end wrench. Sort of wish now I had kept the 4" x 6" for cutting jobs more suitable to it.
   Ken Scharabok (Poor Boy) - Sunday, 04/08/07 09:01:33 EDT
Take a look at the 350 pound double-heeled Fisher at eBay #110111771573. Steve said it is apparently not a one-of-a-kind as he has received reports of others. Steve also said Jock thinks it was an industrial usage. Postman is baffled. I simply cannot think of a practical usage for it. Note the double hardy and pritchel holes.
   Ken Scharabok (Poor Boy) - Sunday, 04/08/07 09:06:24 EDT
Let me advise people about Anvilfire sidebar ads. Neither the Guru nor CSA has any control over the content of the Ads; we should all understand that. The ads are from Google and provide revenue that helps support the site. This is a good thing. HOWEVER....be aware that www.freeringtonez.us is really a joke subscription service and if you sign up for a "FREE" ring tone, you also sign up for the service at $20 per month. You can cancel this service by sending a text message "STOP" to 86595. As with all free offers, read the fine print FIRST!
   quenchcrack - Sunday, 04/08/07 09:34:44 EDT
IIRC, companies that make hazardous waste automatically get "generator" licenses that let them store the waste for up to 90 days prior to disposal. Accepting waste from someone else probably requires a special license and a major paperwork drill to get it. So, as ViCopper points out, it can't hurt to ask, but don't be too surprised if the answer is "no."
   Mike BR - Sunday, 04/08/07 10:09:05 EDT
Deb Johnson: After looking at the photos in your eBay listing I now strongly suspect 1881 isn't a date but a serial number. My guess is a 1900 made Arm & Hammer, but... Oval depression in bottom could be Trenton also. I'm not sure about A&H, but very early Trentons had a flat base. Feel the area under the heel. If rough forged there, likely an A&H. If smooth, likely a Trenton. I suspect there may be another digit to the serial number though, making it later for an A&H than 1900 or later than 1898 for a Trenton.
   Ken Scharabok (Poor Boy) - Sunday, 04/08/07 11:33:11 EDT
Machine Tool Sizes: Yep, there is a size that is best for every job. At home and in our family shop we had little 6" Craftsman hobby lathes as well as bigger 13" 16" and 20" professional machine tools. For anything an inch or smaller that did not need tight tolerances the little under powered 6" lathes get used because they are easy tp use.
   - guru - Sunday, 04/08/07 12:26:26 EDT
i live in eastern pa,i'm new to the smithing and enjoy it very much. i've recently purchased an anvil with a star on it. i belive its cast steel with a hardend face plate , can you help me identify this anvil? no other marking that i can see,weighs about 158 lbs,has a 1 inch hardie hole and a.375 pritchel, london pattern. can you tell me if its any good maker wise.thanks i'm sure i'll have more questions later
   robert webbe - Sunday, 04/08/07 12:43:14 EDT
   robert webbe - Sunday, 04/08/07 12:44:41 EDT
Google Ads: If you see REALLY deceptive ads or products that you thing are inappropriate please let me know and I can block them.
Note however that some products such as "Sound Anvil" a sound mixing computer product or "Anvil mixers" a cooking appliance are sold by hundreds of people and I have no way to block such ads that are just in the wrong category. As we all know some keyword based categorization just does not work. . .
I HAD thought about blocking the Horsey ringtones due to the not really being FREE but I cannot protect everyone from everything. Note that MANY "free" things on the net are paid for by giving them your e-mail address or phone number which they are then free to market to (by law). You pay by being deluged with SPAM and telemarketers. But that is a choice YOU make. Nothing is free, even the "free" advice we give has a cost (ads).
   - guru - Sunday, 04/08/07 12:54:24 EDT
STAR anvils: Robert, the only star anvil I have had was a cast iron anvil with a then steel face plate. These are manufactured by the Fisher process where the plate was welded in the casting process. The Star I had was the cheapest made I have seen and the plate was broken and loose.
The advantage of steel faced cast iron anvils is that they do not ring loudly. The disadvantage is that they do not have quite the rebound of a good steel or steel and wrought anvil. They are also nearly impossible to repair if the plate comes loose. Cast iron steel faced anvils also by necessity have thick heels which some folks do not like.
There are those that love this type anvil and those that hate it. If it is in decent condition then you have a good sized anvil that you can produce a lot of work with.
   - guru - Sunday, 04/08/07 13:02:41 EDT
Robert Webbe, I have a hot cut with a star on it. I think it was made by Iron City Forge, probably in Pittsburg. Ken S should be able to confirm or debunk that opinion.
Guru: No complaints from me on the ads. I should have practiced what I preach. It is not your job to protect anyone from their own stupidity. These merchants are found everywhere and you just need to be eternally vigilant.
   quenchcrack - Sunday, 04/08/07 13:03:28 EDT
Two anvils had stars basically as the logo.
North Star is a Swedish anvil. Would be cast steel.
The other is American Star. Looks like a very early Fisher & Norris, probably from the mid-1800s. Cast steel with an steel plate. Likely also made in Trenton, NJ. The novelty of this one was a large, deep hole in the bottom called a tempering cavity. Not all that rare. I've seen perhaps 6-8 on eBay over the past couple of years.
Primary source: Anvils in America by Richard Postman.
By the way, received a note from Richard he is pretty well not going any where this year (Quad-State possibly excluded) to finish More on Anvils. It won't be a rewrite of AIA, but rather a supplement to it. Originally was to primarily focus on additional English anvil manufacturers, but I suspect he has found out quite about bit more about U.S. anvils since AIA was finished.
Remember the Anvilfire.com Hammer-in will be on my farm near Waverly, TN primarily on Saturday, April 21st. Ptree will be demonstrating wizard heads. Guru will be doing powerhammer tips and techniques as best he can on my limited equipment. May be other impromptu demonstrations.
Tie in to discussion is it is your chance to see one of only two known anvils solely marked as a DUNN & MURCOTT, BROOKLYN, NY with a serial number. Two others are known to have their stamp, plus AMERICAN (American Wrought Anvil Company, Brooklyn, NY) who apparently acquired D&M and changed names.
Last year attendance was about 30. From additional publicity I expect perhaps twice or so that many this year.
If you want event details just click on my name and request them.
   Ken Scharabok (Poor Boy) - Sunday, 04/08/07 14:27:28 EDT
thanks guys. mine does have said cavity,any further thought on quality. this is going to be a user, no cracks ,one chip pretty small. light rust on face.just wondering what to look out for,thanks again.
   robert webbe - Sunday, 04/08/07 14:45:36 EDT
Robert Webbe: Quality should be every bit as good as a Fisher & Norris from the same period. As long as the top plate is firmly attached to the body you should get indefinite use out of it. If the edges are sharp you may want to put a bit of a radii on them to help prevent edge breakage.
   Ken Scharabok (Poor Boy) - Sunday, 04/08/07 19:31:25 EDT
I was once told of a susposed old method of preventing a blade from rusting was to rub the blade with a cow horn during the tempering process this allows the horn to burn and in this process releasing oils into the blade, helping prevent rust. i would like to know if this process works and if there is any histrocal evidance supporting it. If you can get me an answer i would appreciate it
Sincarley
Alan J Grillot
   - Alan J Grillot - Sunday, 04/08/07 23:38:18 EDT
Alan, No, No, and no.
   - guru - Monday, 04/09/07 04:53:28 EDT
...and no, the stench of burning horn is something you DONT want to have in your nostrils.
   - Nippulini - Monday, 04/09/07 08:03:13 EDT
The stench.
A farrier fitting hot horseshoes becomes inured.
   Frank Turley - Monday, 04/09/07 08:30:29 EDT
I found a near perfect anvil that has a name on it of Nohab 14 sweden. I can't find any info on this .any help as to a web site. thanks much
   mark - Monday, 04/09/07 08:36:53 EDT
Mark, are you sure? Are there gaps in the lettering? There was a North Star Brand that was imported from Sweden in the 1940's. The one in Anvils in America looks like a Kohlswa ( a current Swedish anvil manufacturer) in shape.
All the imported Swedish anvils have been good anvils if not a little too hard.
   - guru - Monday, 04/09/07 09:05:52 EDT
I have just started to try to learn to forge weld. It is normally snowing when I am at the forge. Not good for forge welding. I have had a limited success. I can get the weld to take, and make the line disappear, but after I Quench it in water. I can pull it apart. It was held together but not very strong. I used 20 mule borax, and heated the steel to just before it starts to spark. and I try to make my first few hit of medium(pretty vague) contact. Any tips on where I may be going wrong?
   Sean Alexander - Monday, 04/09/07 13:14:55 EDT
Sean, I've found that on the first heat I get the parts together, re-flux, and then on the second heat finish shaping while the metal is still in the yellow range. Any forging below this temp and the welds don't seem to hold as well. This works for me anyway.
   Mike H. - Monday, 04/09/07 13:46:52 EDT
Alan this may be a variation of a method that Theophilus wrote about in 1120 CE in his book "Divers Arts". He mentions heating the iron and burning featers on it to leave a coating that helps prevent rust and has a pleasing look to it. I have not tried this out---yet.
   Thomas P - Monday, 04/09/07 14:16:30 EDT
Guru, I love your sight! I am one of those that in spite of perfectly sound advice decided to 'fix' an old anvil that was missing part of the top plate a couple years ago (and it's quite a story). Well needless to say I am in the market for a new anvil and have been monitoring the comments here as well as researching anvil manufacturers.
There are three anvils I am considering and need some help determining which would be the best investment. I am looking in the 250-275lb range for Peddinghaus, Nimbus and Rathole Forge. You seem to be a strong supporter of Peddinghaus and I have heard some really good things about Numbus. I really like the look of Rathole Forge anvils but I am not sure which would make the best investment. They are all in the $1,500 range and shipping for any to my area is about the same. Any thoughts, comments, suggestions or experiences would be greatly appreciated.
   Rhordae - Monday, 04/09/07 14:22:07 EDT
Decisions, decisions. . .
If I had the money it would be a hard decision. Peddinghaus is the best in material but lack in fit and finish. They have not been up to what I consider "German" standards for many years. They are also in and out of production and hard to get.
Between the Rat-Hole and Nimba there is probably not much difference in quality metallurgically and in finish. however, the Rat-Hole is a work of art. They took some of the most classic features of well designed anvils and combined them into the most beautiful anvil of the last century and a half. They are pretty much custom made in low quantities and you never know when they are going to quit or the foundry become too difficult to work with. This makes them a good long term investment.
However, all three of these lines do not depreciate much as used tools so they are all a good financial investment as well as being good tools.
   - guru - Monday, 04/09/07 14:37:53 EDT
Failing welds: Sean, First, it is bad practice to quench steel while too hot. Second, cleanliness is next to Godliness when it comes to welding. Descale with a stiff brush, flux early and DO NOT burn the steel. Just below sparking is good for low carbon or mild steel but will burn higher carbon and alloy steels.
When you bring a piece to welding temperature the surface that is nearly liquid decarburizes rapidly. SO when you make a weld there is a lower carbon zone in the joint that may also have some dirt inclusions as well. This makes the joint weaker than the rest. SO. . keep it clean
In wrought iron it was nothing except a mass of welds so another one doesn't make much difference. But in steel a forge weld joint is often a weak point unless it is well made. You also need to look at the shape of the joint and how long of bars you are using for leverage. Anything can be broken under the right conditions.
   - guru - Monday, 04/09/07 14:48:06 EDT
The Rathole anvil looks like it is made from two pieces where the Nimbas are one solid chunk-o-steel. Would that make a difference in the working quality of the anvils? I heard that Nimba's ring really loud but that aside would the Nimba actually be a more 'solid' anvil because of its construction? Or am I wrong about the Rathole?
   Rhordae - Monday, 04/09/07 15:17:02 EDT
The Rat-hole is a one piece casting just like the Nimba and of similar material. Most cast steel anvils ring quite loud and need some deadening.
   - guru - Monday, 04/09/07 15:22:33 EDT
Thanks, I am using a mild steel, and I actually hot filed the surfaces and quickly fluxed them. I then put them back into the coal forge, and brought them up to a yellow heat.
Each piece of steel was about 1-1.5' long, and the weld was about 1.5 inches long. I believe that it could be a combination of low carbon zone and leverage. It did not bend much just a little and then it would break, and I could see the "Crystaline" Stucture where the two surfaces were attached.
Well back to the forge always learning!!
   Sean Alexander - Monday, 04/09/07 15:30:25 EDT
Thanks Guru for your prompt replies and unwavering dedication to such an incredible and informative site!
   Rhordae - Monday, 04/09/07 15:36:44 EDT
Sean.
There are very few times when one would quench a weld, and this goes for arc and oxy welds, as well. A couple of instances when a forge weld is quenched: a pattern welded knife blade; a link shaped fire-steel. A mild steel weld, when quenched, may result in a "contraction crack". Mild steel forge welds are normally air cooled, sometimes annealed.
Rhordae,
I'm using a Rathole, cast in one piece. If you make a steel tray for the base and paritally fill it with sand, it deadens the sound pretty well.
   Frank Turley - Monday, 04/09/07 19:57:27 EDT
I would like a Rathole Forge Anvil. I am afraid it may chase my Mouse Hole Forge anvil around and eat it. I don't think I could keep enough cheese for both.
   - Hit & Miss - Monday, 04/09/07 21:06:13 EDT
Does anyone know where to get these small anvils used , well, for what ive seen, as sword smithing anvils?
theyre in a couple videos from youtube,a nd a couple sites, the sites i forget but, heres the videos
http://youtube.com/watch?v=rt_V-9TqpoM
http://youtube.com/watch?v=R0DwAWut3b8
http://youtube.com/watch?v=B_JcP0AASFw
and
http://www.chenessinc.com/forge/ba-hammering_katana.jpg
and, does anyone know what type of steel they are made from or anything about them?
thanks,
Cam
   Cameron - Monday, 04/09/07 21:47:07 EDT
I was hoping someone has seen Ron Kinyon's new version of his air hammer with the leaf spring ram mount. I understand he may be putting together a new set of plans with this modification and wanted to know if anyone had any information about this.
   Steven Bronstein - Monday, 04/09/07 22:16:25 EDT
Hi there.
Is it possible to Mig-weld tool steel S5?
Stef.
   stef - Monday, 04/09/07 22:56:51 EDT
Thanks for letting me know that burning a horn on a blade will not help prevent rust. I do agree that the smell of burning cow horn is not something that i want in my shop. Than does however lead me to another question. what is a method that i can use to prevent rust that is inexpensive and readily available in a small city. I live in Pittsburg Kansas. In the area we have quite a few farms and farm stores if that is any help for your suggestions.
sincerely
Alan J Grillot
   - Alan J Grillot - Monday, 04/09/07 23:03:57 EDT
Rhordae,
I use a Nimba anvil, and love it. The things I like best about the Nimba are the design and the quality of the workmanship. The horn is shaped beautifully and is eminently useable, and the face is very wide with a tremendous amount of mass under it. That mass under the face makes the anvil work like one that is considerably heavier, compared to the London or American pattern anvils with their narrow waists. While some people think the wide face is a disadvantage, the nimba's tapered heel is, effectively, a face of almost any width you want.
The Nimba isn't as snazzy looking as the Rathole, nor a classic-looking as whatever Wile E. Coyote is dropping on unwary roadrunners, but it IS a remarkably well thought out piece of forging equipment.
My Nimba was excruciatingly loud until I mounted it o a proper stand with a bed of Geocel silicone consruction adhesive under it. After that, it is very nearly as quiet as my Fisher; no "ring" at all.
   vicopper - Monday, 04/09/07 23:14:38 EDT
Alan,
Rub a bit of Vaseline on it. Vaseline is just a cleaner version of the old military Cosmoline that has prevented rust for a century.
   vicopper - Monday, 04/09/07 23:16:31 EDT
Cameron, I couldn't find anything on youtube except a misch masch of stuff, but the anvil shown on katana is a small cast iron Chinese anvil. You'd probably have to go to China to get one. The Chinese have been making that style for quite a few years. Because they make swords on them doesn't mean they are all that wonderful.
   Frank Turley - Monday, 04/09/07 23:23:54 EDT
Chinese Anvils: Cameron, these are a standard Chinese anvil. I believe that they are traditionally cast iron (not very good). But that is the Chinese tradition. They jumped past the wrought iron and steel stage to cast iron very early (before Europeans could make cast iron) and thus many of their tools were cast. They made a huge technological leap which caused their technological development to falter. Many of their traditional tools are stuck there.
Since these are considered sub-standard anvils by the rest of the world there is no export market in them. There may be some made of steel but that is not the "tradition". However, a piece of structural plate flame cut to that shape is about as good if that is what you want.
Note that while many of the videos on the net are of "Japanese" sword forging, these are being made in China by hand in low wage shops, (thus the Chinese tools).
   - guru - Monday, 04/09/07 23:25:01 EDT
MIG welding tool steel: I would not recommend it but it can be done with the right wire. The results are not going to be spectacular. Specialty high manganese rods do a much better job on tool steels.
Note that in any type of arc welding of high carbon tool steels you will need to preheat and post heat treat to reduce extreme brittleness at the joint.
   - guru - Monday, 04/09/07 23:34:25 EDT
Mark. Nohab was a Swedish manufacturer that made excellent airhammers, and since almost every Swedish steelmill made their own anvils in the past one can assume they also made ordinary anvils. I´d guess it is a cast steel anvil..
   - Bo - Tuesday, 04/10/07 03:04:50 EDT
Hi everyone
I have a E.C. Atkins Kwik Kut #7 machanical? hacksaw
I know its for metal and it ran by steam? and its better then excellant shape can anyone tell me anything about it
I will probably sell it but I am unable to find a #7 information. I also have a Drill press excelsior 21 royersford that I know very much about but both very facinating equipment
Thanks alot april
   - april showers - Tuesday, 04/10/07 06:19:35 EDT
Hi everyone
Thanks alot april
   - april showers - Tuesday, 04/10/07 06:21:31 EDT
Cameron
Those anvils appear to be something they made for their specific use. They may have been a machine part or just scrap they modified. It appears they forge welded on face that they made convex for drawing purposes. I could here the ring in the video. I do not believe they are cast iron. The Chinese are smart and use good tools themselves, though they may appear primitive.
   - Hit & Miss - Tuesday, 04/10/07 07:45:29 EDT
Rust:
I mix Vaseline with kerosene and put it in a spray bottle. That worked great this winter, which was pretty bad from a condensation point of view. I got that recipe from this forum.
   - Marc - Tuesday, 04/10/07 07:59:58 EDT
Alan,
For a cold rub application, linseed oil works rather well. You can get it at just about any hardware store and it is inexpensive. Mink oil works too.
vicopper,
What size Nimba do you use? I REALLY like the Nimbas and am having a hard time deciding between that and the Rathole. The decision may be made for me however since Nimba emailed me back with pricing quotes within hours and Rathole seems to not check their emails at all.
   Rhordae - Tuesday, 04/10/07 09:15:17 EDT
Rhordae:
Willene Jacqua of Nimba anvils is a PLEASURE to deal with, and they REALLY stand behind their product. Oh, and I love my Nimba as well. I have the 120lb Titan. VICopper has the Gladiator (Sweet).
I am sure RatHole is a great anvil as well. Tough decision for you I guess.
   Mike Berube - Tuesday, 04/10/07 09:43:51 EDT
I'm just waiting for the sea to start rising and then I'm going to spread the rumour that the US VI are sinking due to the weight of NIMBA anvils and they should be *immediately* shipped to me out here in NM as I have over 4000' before I have to worry...
Traditional Japanese swordsmithing anvils look a lot like western sawyers anvils. I see a couple most years at Quad-State; however I would probably just try to find a couple of worn out H13 dies that I could buy for scrap price and use the flat side/end of them.
May I commend to your attention the National Geographic Special on "Living Treasures of Japan" for their sword forging scenes. My local public library in OH had a copy and I can now ILL a copy at my new public library here in NM.
   Thomas P - Tuesday, 04/10/07 12:23:17 EDT
Rhordae,
As Mike said, I have the Nimba Gladiator, at 450#. It is a truly wonderful anvil. Yes, they cost a lot. They're absolutely worth every penny, if you love great tools. Excellent casting, superb finish, and a shape that is designed for serious forging. The 450# makes a very noticeable difference in efficiency when forging bigger stock, but is probably overkill if you're not planning to work stock much over 3/4" regularly.
The late Russell Jacqua, an excellent blacksmith, designed the Nimba and used to personally hand finish every one. Since his unfortunate and untimely death, his widow Willene is running the business and by all accounts doing a great job. You won't find a better place to do business with no matter how hard you look.
If you do decide on the Nimba, please tell Willene that you were persuaded by information you got here on Anvilfire, and suggest that she might benefit from advertising here. Advertising revenues are what keeps this site afloat so we can continue to recommend fine tools like the Nimba.
   vicopper - Tuesday, 04/10/07 12:43:04 EDT
Thoomas,
I've given serious thought to your hypothesis and I do believe you're right. I'm unwilling to give up my Nimba however, so I'm sending you a few thousand pounds of scrap cast iron, freight collect. That should offset the Nimba's mass very handily and even leave me room to lay in some forging stock. (grin)
Thanks for caring!
   vicopper - Tuesday, 04/10/07 12:46:00 EDT
You can do that? Sending "freight collect"? I must not think evil thoughts, I must not think evil thoughts, I must not think evil thoughts........
   - Nippulini - Tuesday, 04/10/07 12:53:10 EDT
Clarifications : China vs. Japan: As I noted, there is a huge industry in China making cheap Japanese swords. They use Chinese methods and tools and thus are not making a 100% traditional Japanese product. THIS is what is being heavily advertised by way of YouTube videos. If you want to learn Japanese methods then that is NOT the place to learn.
The Chinese anvils shown in the links are of unknown material. However, traditional Chinese anvils are made of cast iron and is the reason the tops have huge rounded corners. This is from wear and new anvils being made to look like well worn anvils. In China at Work by Rudolph Hommel, he shows this type anvil and clearly states they are cast iron but an odd grade that may be near to steel. However, the example he shows has the distinct texture of pulverized cast iron on all the working surfaces This was in the 1930's and the style of the anvil used by the Chinese has not changed.
I have a painting of a "traditional" Chinese shop that has a slightly different type of anvil. At first we thought it was a piece of industrial scrap but it has the features of the classic Chinese anvil. It has the bread loaf shaped main working section and two shelves. However on this anvil they are both on one side of a long anvil and are fully supported (do not have the sloping bottom surface that makes the others look like a horn). This is a heavier version of the type with horn like shelves.
The Chinese have a VERY different idea of what an anvil should look like than we do in the West. It may be why they have such a difficult time making patterns for Western style anvils.
   - guru - Tuesday, 04/10/07 13:11:35 EDT
I have been given a box ( about 150 ) of cutoff arrows from a fletchers shop, most are 6" to 8" long and alum. Any ideas for a use? I just couldn't say no.
   daveb - Tuesday, 04/10/07 13:35:13 EDT
Hmmmmmm more of your sculpture. . .
   - guru - Tuesday, 04/10/07 13:45:30 EDT
Nipp, vicopper:
"Freight Collect"...thanks for the laugh. I needed that :-).
   Mike Berube - Tuesday, 04/10/07 14:50:20 EDT
Daveb,
you could possibly make mini crossbow bolts, they would be around that size,
   Cameron - Tuesday, 04/10/07 15:12:56 EDT
I'm getting ready to make a couple of door knockers, and I want to cut the corners of the backer plate with a semicircle, about a 1/2 inch diameter. I could drill it out but would prefer to cut it out hot. Should I forge one of my bigger chisels into a round like a gouge or is this a hardy tool kind of operation? Can't recall where I saw a rounded hot cut for the hardy hole. Checked the advertisers and didn't see one.
Thank you,
   Michael - Tuesday, 04/10/07 15:21:45 EDT
the all time best antirust for a dripping condensing shop. Someone on this site suggested an oscillating fan left on all the time and aimed at the ceiling to help to reduce rust in a metal sided shop. I have a metal sided shop that will rain inside when the temps change. The dirt floor helps in the humidity some I am sure.
The fan was installed before the fall last year, and it has been an absolute success. NO dripping!!! I do now get a little light rust on bare surfaces, but I just use WD-40 on the stuff that needs a light oil, and the sulfanate oil on the anvils and swage block ETC. The little 14" fan was a left over, sitting out of use, and uses almost no electricity, as the motor is maybe a 20th of a Hp.
To whom ever made the suggestion, Many Many thanks.
   ptree - Tuesday, 04/10/07 16:38:50 EDT
IIRC a Farrier's supply co will sell the curved hardies.
However I find I like to look at where the chisel hits the work to get things lined up so I would go with a hand held curved chisel---pretty easy to forge.
Rich does the Govenor know that you will be shipping all that cast iron away---they only thing that's keeping the magnetic field of the Nimba from pulling in every hurricane for 500 miles of the islands?---you're bringing the Nimba to Quad-State to show it off aren't you?
   Thomas P - Tuesday, 04/10/07 16:56:54 EDT
I am looking to start to get into metal working and have decided to start with copper, however I have not been able to find much information. I am looking to make some copper runes and other such items. I would be great full if someone can provide sources such as sites or books as there where I can get started. I am currently working on building a drumbrake forge but it has been slow going.
Mightywetfoot
   Mightywetfoot - Tuesday, 04/10/07 17:03:15 EDT
Thanks Thomas, looks like I've got another tool to forge.
   Michael - Tuesday, 04/10/07 18:15:26 EDT
Wetfoot, I have made rune sets from river stones pulled from the creek in my backyard. I used a diamond tip engraving tool for those. Iron runes would be more appropos, copper is a little too flashy for Vikings.
   - Nippulini - Tuesday, 04/10/07 18:20:22 EDT
Ptree,
I don't remember who originally posted about the fan, but I've been thinking about it since. I figure that when the weather changes and your shop fills with warm, humid air, the cold surfaces start cooling the immediately adjacent air. Once the surrounding air drops below the dew point, condensation starts. If the fan can blow the air away before it cools that much, it will prevent condensation.
If my theory's right, adjusting or supplementing the fan so you get good circulation around your equipment might stop the surface rust also.
   Mike BR - Tuesday, 04/10/07 18:36:40 EDT
april showers-- the Royersford Excelsior 21 is a marvel, a thing of beauty and a joy forever. Keep it well lubed. The estimable Guruissimo helped me bring mine back from the dead a few years ago-- 1998-- and I now use it just about every day.
   Miles Undercut - Tuesday, 04/10/07 20:18:40 EDT
Working Copper: Mightlywetfoot, Look up silver smithing. Everything applies to non-ferrous. Copper is one of the softest and must ductile metals there is next to gold. You can hammer it cold, roll it, bend, punch and work hot as well. Copper is excellent for repousse' (bas relief in metal). We have reviews of the two best books on the subject of working non-ferrous metals. Metal Techniques for Craftsmen and Metal Working. For inspiration in mixed metals see the late Dona Meilach's Decorative and Sculptural Ironwork.
A strip of runes in repousse' on copper would be a nice decorative piece that could be turned into an arm band, braceket or other device.
   - guru - Tuesday, 04/10/07 23:21:18 EDT
Oh... I was going along the lines of runes for divination. I used to read stone castings (similar to tarot cards)
   - Nippulini - Wednesday, 04/11/07 07:11:57 EDT
what do you mean the "late" dona meilach? last i heard she was gathering more photos for another book. if its not a typo , that's really really bad news. her books were fantastic. so much inspiration in those pages. what happened? bad bad news. sympathy to any family reading this.
cooling down in brisbane australia, 11-28 cel.dry.
we need rain,lots and lots of rain!!!!
   - wayne - Wednesday, 04/11/07 08:20:25 EDT
Wayne, Sorry to be the bearer of sad news. I found out months after the fact myself. Dona died in January after a long fight against cancer. Se was 80 years old, which surprised me. When I met her in 2000 I would have guessed mid 60's. Her publisher Schiffer Books is continuing the series of books she had started for them.
   - guru - Wednesday, 04/11/07 09:41:53 EDT
Working Copper
Thank you both for your quick responses, I will look into getting those books. As far as runes I am looking into both for casting and to put on metal work. I also want to create some authentic looking bronze and cooper ax's and tools to get out some use of my anthropology schooling.
   Mightywetfoot - Wednesday, 04/11/07 13:09:42 EDT
MightyWF, visit the ancient weapons forum over at swordforum.com to converse with folks actually making such items---some using the original methods as well!
   Thomas P - Wednesday, 04/11/07 13:16:55 EDT
Bronze Age Tools: These were primarily cast. After casting some were used as-is and others were finished. Much of the bronze age hammering was done to decorate tools, weapons and jewelery. During the late bronze age in Britain and Europe stone, bronze and iron tools were used to work bronze. Hammered, work hardened bronze chisels were used to apply decorations. Anvils were small odd things used primarily on jewelery. Padded stone work surfaced were used to support larger items. Since the metal was not being hot forged a true anvil had little use.
While bronze and copper can be hot worked and is very malleable it is much easier to produce an axe shape or an eyed tool by casting. Many of the molds used during this period were permanent stone molds made of soap stone or other heat resistant stone. Molds were both single open face and double two part closed molds. The result was that a large quantity of similar items could be cast in a short time. Some molds were quite detailed.
Edged tools had their edges cast close to finished but were hammered to create a thin sharp edge.
   - guru - Wednesday, 04/11/07 13:52:44 EDT
i am very interested inn metalurgy and black smithing. any info on were i can learn the trade, get help, and even find a master smith in kentucky, usa.?
   - grieveedge - Wednesday, 04/11/07 14:44:52 EDT
   - grieveedge - Wednesday, 04/11/07 14:45:07 EDT
grieveedge: Try these contact points:
KENTUCKY BLACKSMITHS' ASSOCIATION
Pres: Andy Bennet, Jr.
PO Box 366
Brandenburg, KY 40108
(207) 422-3107
Ed: Larry Zoeller
4312 Lahnna Drive
Louisville, KY 40216
(502) 361-0706
zman59@earthlink.net
http://ky.abana-chapter.com
If you haven't already done so click on the link at the top of the page for Getting Started in Blacksmithing. Lots and lots of good information there.
I don't know where in KY you are, but avvilfire.com is having a hammer-in on my farm near Waverly, TN weekend after next. You can just click on my name to request conference information. Your chance not only to see some demonstrations, and perhaps hands-on instruction, but to meet and greet fellow blacksmiths from the general area. If you are looking for tools and equipment we expect some tailgate sellers at the event.
   - Ken Scharabok (Poor Boy) - Wednesday, 04/11/07 15:51:35 EDT
grieveedge,
If you are in the Louisville Ky area, I live in Floyds knobs, just across the river from Louisville. The Indiana Blacksmithing Association is very active, there are monthly meetings with open forge time for beginners, in North Vernon, very near Semour IN. They also have a very nice conference the first weekend in June, in Tipton, near Indianapolis. And i too will be at the CSI hammer-in at Ken's farm.
   ptree - Wednesday, 04/11/07 17:09:46 EDT
And. . as I often point out. These meetings usually have demos as well as short courses (green coal classes). If you are willing to travel a little you can be at a meeting almost every weekend. Besides seeing it done, you get a chance at hands on AND there are almost always folks there selling tools (new and used). You will also get to visit a number of shops as most groups rotate where they meet. Some will be professional and others back yard hobbiest. But this will let you see just how varied blacksmithing IS.
In the old days a blacksmith graduated from apprentice to journeyman. The journeyman, as his title says was supposed to travel and work in other shops in order to gain experience and learn more than he could from a single master. Today in the US you can pick up a lot of that knowledge by going to association meetings and conferences.
Upcoming major conferences include SBA (Southern Blacksmiths Association) who put on a regional conference in Georgia. It is a great conference and worth much more in educational than they charge and your travel cost will be.
In July the Canadians are having another CanIron. This is a wonderfully different gathering and quite international. You can learn in days what might take years to see otherwise. Do you have a PASSPORT?. You will need one if you live in the U.S.
Our event in Tennessee is FREE, but we do ask that you bring something for Iron-In-The-Hat. There will be demonstrations and tailgating (a chance to buy tools you wouldn't see elsewhere).
   - guru - Wednesday, 04/11/07 17:59:22 EDT
thanks guru. from her writing I'd have guessed much younger.once again, sad news.
   - wayne - Wednesday, 04/11/07 20:15:34 EDT
Mark: From the photographs you sent my SWAG is your NOHAB anvil was made from them by Soderfors. Looks like their Peter Wright copy. My WAG on date would be sometime during the first half of the 1900s.
   Ken Scharabok (Poor Boy) - Thursday, 04/12/07 01:12:24 EDT
I had posted a question about the Clackson scroll formula, hoping the guru might be able to answer it, but it has disappeared in the meantime.
Anyway, a friend directed me to Wikipedia, where I have found details. Having tried it out, it gives a good estimate of the length of metal required for making a scroll and takes the guesswork out of ordering the right length of stock.
   Derek Rae - Thursday, 04/12/07 05:49:03 EDT
Not a proper "blacksmith" question, but I really am trying. I was recently given a new-fangled electric-type drill press thingy and I would like to know what speed to set it at for drilling your average black mild 15mm thick steel plate. I'm worried about burning my bits, if you know what I mean. If the worst should happen, can you re-temper a good quality drill bit?
   Craig - Thursday, 04/12/07 06:33:51 EDT
Speeds and Feeds: Craig, many drill presses will not go slow enough for steel. The thickness is not an issue. The critical parameters ARE. .
Material (type of steel)
Diameter of the bit.
Cutting speed is given in linear feet per minute. This is then converted to RPM.
We are assuming good quality HSS drill bits, not antiques.
For most mild steel the cutting speed for drill is around 120 to 100 Feet per minute. For stainless and tool steel it is about 90 feet per minute or less. Bits last longer at low speed. Published values (see Machinery's Handbook) may be higher but also assume heavy duty machine shop equipment and professional operators.
SO. . . for each size bit there is a different speed. The larger the bit, the slower the RPM.
I'll calculate in English units then convert to nearest MM.
120 * 12 / Dia * PI = RPM (high)
3/8" (10mm) = 1222 RPM
1/2" (13mm) = 917
9/16" (14mm) = 814
5/8" (16mm) = 733
3/4" (19mm) = 611
7/8" (22mm) = 523
1" (25.4mm) = 458
Now. . . I run at about 100 FPM which is 80% of the above speeds and use thin oil for chip coolant. Drill bits last for hundreds of holes between sharpening on average.
Drill presses designed for wood working rarely go slow enough for drill bits larger than 3/8" (10mm). Unless all you do is very small work then they have no place in the metal shop.
Feed pressure is also critical. Making a good healthy chip is better on the bit than going too slow. Not cutting, just rubbing, work hardens the metal and heats the bit resulting in worn chipped or broken bits. Not clearing chips in deep hole is a problem but worse is riding on top of a chip that has fallen back into the hole. NOT having sufficient feed pressure is why drill bits are rapidly burned up by hand held drills.
Finally, how you handle the "break through" at the bottom of the hole is critical and requires some skill. As the hole opens less pressure is required and the bit will try to crew itself through the thin edges rather than cutting. At this point you have to slow the feed (reduce the pressure of even hold back) so that the bit cuts the last metal no faster than it has the rest. Chipped edges and broken bits result from not paying attention to the break through. The "feel" from the feed back in a sensitive drill press is a critical part of learning to drill holes.
Feed rate in distance per turn can be set on many machine tools but is only used for drilling on fully automatic drills.
NEVER, step drill unless you need the precision for some reason. Step drilling is a hand drill crutch that solves the lack of feed pressure problem by substituting other problems. Controlling the feed rate (holding back) is critical when you step drill. Otherwise the bit sees too much load and you break the corners off the bit. When you step drill on a drill press it should only be done on machines that have an automatic feed for boring. Thus the machine feeds forward a controlled amount all the way through the hole. It is still hard on corners. Step drilling does not solve the problem of turning too fast.
This IS a blacksmithing question. . .
   - guru - Thursday, 04/12/07 09:53:45 EDT
More drilling speeds. Many drill presses do not have fine speed adjustments. For average work I keep mine at the next to the slowest speed (in straight gear). When drilling small deep holes the low speed gives one a better feel and I get a better rate of success.
However, in a job-shop environment where profits are measured in pounds of chips made per hour you push the performance envelope to the max. It is like running a race. You run 10% higher than the highest published speeds using coolant and use higher feed rates. If chips are not blue you are not running fast enough. As soon as bit wear can be detected they are replaced, the dull ones set aside to be resharpened by a specialist. Small bits are often discarded as it is cheaper to buy new than the resharpen used.
   - guru - Thursday, 04/12/07 10:09:12 EDT
Measuring Spirals: Derek, you must have posted that somewhere else.
A true spiral is a simple slope. Given the distance from the center as one side of a right triangle and the number of turns times PI times half the diameter as the other the length of the spiral is the hypotenuse (more or less).
Hmmm. . that is the radius in both cases.
Most blacksmiths just bend a piece of wire to the planned spiral and then straighten and measure it. You can also use a roller measure (map wheel) on a scale drawing (OR an old fashioned blacksmiths traveler). Wheel tools for measurement have been around for centuries if not millinium.
   - guru - Thursday, 04/12/07 10:23:03 EDT
Gents,
I've found a source of what may be old wrought iron, but I'm not entirely sure whether it is. The badly rusted surface seems more pitted than grainy, but there are some spots that do seem to show a linear grain. I've tried cutting a piece nearly all the way through and then breaking it the rest of the way; the break wasn't as "doughy" as I expected, but the metal at the point of the break does seem to have a grainy, somewhat fibrous appearance. I also tried letting it sit in vinegar overnight (my less hazardous, slower-acting version of the nitric acid test mentioned in the wrought iron FAQ here); this morning the cut ends were still bright, which hasn't been the case when I've done the same thing with steel. But the other steels I've soaked in vinegar were pretty high in carbon, which might make a difference, so I'm not sure that little experiment proves that what I have is wrought iron versus, say, mild steel.
Can anyone point me to any good photos of what the broken ends of wrought iron and mild steel look like, for comparison purposes? Any other hints on verifying that it's wrought?
   Matt - Thursday, 04/12/07 13:16:41 EDT
PS -- Here's a photo of a small piece of it: http://i56.photobucket.com/albums/g170/mandmphotos/iron.jpg
   Matt - Thursday, 04/12/07 13:29:28 EDT
I showed a teacher friend of mine who is scottish , the sgian dubh i made, and he would like me to make him one, but with a different pattern,
other than, Cable, And roller chain damascus, what are some damascus patterns that can be done with semi easy to find scrap, i dont want to have to buy sheets of certain steels, i just want to grab some steel and weld it together, ive heard you can make some damascus out of singlemetal bandsaw blades, with something else inbetween, and since he wants a twisted damascus pattern i think that would work best, but, does anyone know how that is supposed to be done? also, the whole process of making star twist damascus, with a billet?
Cam
   Cameron - Thursday, 04/12/07 14:16:57 EDT
Many of the single metal bandsaw blades are L6 steel (you want the really big blades, not the type you get for your little shop bandsaw) Recently I've seen some good contrast damascus made with L6 bandsaw steel and 1084. On the whole there arent a whole lot of high carbon sources for damascus that you can 'find as scrap' besides things like motorcycle primary chains, cable, and the like, everything else needs to be cut, cleaned, and layered for the most part.
   Jmercier - Thursday, 04/12/07 14:40:48 EDT
Bandsaw blade steel and steel strapping -- the kind they used to secure heavy loads to pallets for shipping -- is a fairly common combination. I've heard the steel strapping is supposed to be close to 1095. I find the 1" wide strapping in the scrap bin at my local structural steel warehouse.
   Matt - Thursday, 04/12/07 14:41:59 EDT
Cam; if you go over to anvilfire's hammer-in forum you will find a link to "Thomas's pizza mutilating device" that shows an exampl of bandsaw blate and pallet strapping done as a 40 layer twist.
As for instructions; I'm sorry I am not going to type out a half dozen pages on how to do it when you can get Hrisoulas' books that describe it in detial by interlibrary loan from your local library.
A couple of tips though: round the billet *throughly* before twisting; twist when very hot, the stars show up depending on how deep you grind into the billet---this is shown in the books very nicely with the pattern you get when you grind into the billet shown in steps.
Thomas and yes I'm the pizza slasher
   Thomas P - Thursday, 04/12/07 14:54:03 EDT
Matt could you show us the *broken* section not the outside.
   Thomas P - Thursday, 04/12/07 14:54:57 EDT
Break in Wrought: The break test in wrought is supposed to show grains pulling out of either end sort of like when a tree is felled and wood is pulled out at the "hinge". But you need to look close at the break. Steel does not do this at all. The grain in your piece looks to be wrought but it is difficult to tell from the photo. What you look for is changes in the grain direction where welds might be or a piece was folded and welded to itself. In steel you occasionally get a surface grain effect when it is stressed or sharpely bent.
Another thing that raw freshly forged wrought iron does is the rust converts to bright red iron oxide more than does steel. Wrought dust rusts iron oxide red as well and is much brighter than steel rust.
   - guru - Thursday, 04/12/07 15:09:21 EDT
Clackson Scroll Formula: Thank you, guru. I know your hypotenuse method must amount to the same thing, but it seems a lot more complicated than Clackson´s
length of scroll = number of turns squared times spacing between turns times PI
   Derek Rae - Thursday, 04/12/07 15:34:53 EDT
hi ive got a question can u make a anvil?
   john - Thursday, 04/12/07 15:39:31 EDT
for star twist damascus, once you have a billet, do you twist all one way, then hammer flat, then forge what you want, or do you have to twist one way, then twist opposite way every inch or wahtever>?
Cam
   Cameron - Thursday, 04/12/07 15:41:11 EDT
The piece in the pic is actually pretty small (maybe 1/4" diameter or a bit more), and I'm having trouble getting a decent resolution pic of the end grain. I'll give it another try.
guru, your description of a felled tree is very encouraging. On one of the breaks I only cut about halfway through before I broke the piece, and the site of the break looks very much like you're describing.
I'll see what I can do about getting an image.
   Matt - Thursday, 04/12/07 16:17:30 EDT
The detail on this isn't nearly what I'd like, but here's a side view of a break where I'd only cut about halfway through the metal before I broke it:
http://i56.photobucket.com/albums/g170/mandmphotos/iron2a.jpg
The rust in the cut is from the overnight soak in vinegar, followed by riding around in my pocket for most of the day today.
Still working on a useful end pic.
   Matt - Thursday, 04/12/07 16:38:41 EDT
John N; Yes I can make an anvil; can you?
Friends of mine made one and documented it on their website for the "Marco-Krieger Armory", search out that and then go to "that anvil story" link
Matt "green stick fracture" where the break looks fiberous rather than grannular is what you are looking for.
Thomas down a pint of blood
   Thomas P - Thursday, 04/12/07 16:47:41 EDT
Making Anvils: John, Sure, what size? Are you looking for something special? There are a number of manufacturers of anvils today and the production product is much more economical than a special one-off.
While Bealer stated in The art of Blacksmithing that the only tool a blacksmith could not make was his anvil that is not nearly as true today as it was 150 years ago. Today we have large slabs of high carbon steel available and you can do wonders with a cutting torch, an arc welder and an angle grinder (hand held grinder). However, it is a relatively expensive way to go as steel plate sells for half what a finished anvil sells for and there is a lot of waste and labor in this method. Fuel costs for heavy cutting are also not insignificant. Most anvils made today are cast then the face machined. There is some hand finishing on better anvils but it is nothing like hand carving from the rough.
I've made little small bench anvils using a combination of fabrication and forging. A nice stake anvil in the 30 pound range can be forged under a typical small shop 150 pound power hammer such as a Big BLU, Phoenix or Striker.
I've also made patterns and cast small brass anvils. These are more decorative than useful but the process is the same as was used in the Bronze age to make small anvils then.
   - guru - Thursday, 04/12/07 16:47:44 EDT
OK, here are the best two I could get of the end grain:
http://i56.photobucket.com/albums/g170/mandmphotos/iron4.jpg
http://i56.photobucket.com/albums/g170/mandmphotos/iron3.jpg
   Matt - Thursday, 04/12/07 17:06:43 EDT
More about making anvils: I have a friend that has a 500 and 750 pound steam hammer in his shop. Some fairly serious anvil forging could be done under these. . .
Using the flame cutting route a fairly large anvil can be made, especially if the torch is machine guided. I have two torch setups, one that does circles and arcs, the other straight lines. Machine cutting can be relatively smooth and save a lot of grinding time. Steel service centers will also flame cut on one axis using computer guided torches. This can save a lot of setup time and effort.
   - guru - Thursday, 04/12/07 17:32:34 EDT
Wrought Iron: Go here: www.realwroughtiron.com/wiac.htm
   quenchcrack - Thursday, 04/12/07 18:36:11 EDT
Thanks Guru. I think I have been running too fast, and I have chipped the edge of my brand new 10mm at the break thru point, so I will be more vigilant in future.
As for "burnt" bits, is it worth the effort of trying to ressurect them?
   Craig - Thursday, 04/12/07 18:36:36 EDT
Quenchcrack: Been there more than once in the past couple of days. Didn't tell me what I need to know.
   Matt - Thursday, 04/12/07 18:55:18 EDT
Quenchcrack, You gonna be at the CSI hammerin?
   ptree - Thursday, 04/12/07 19:35:59 EDT
Burnt Drill Bits: Most twist drill bits are fine to resharpen unless the sides of the flutes are torn up.
Note however that many of the new "split point" bits have a thick web and cannot be sharpened normally. Regular point drill bits have the web thinned for the last 20% of the bit and can be resharpened until losing about 10% of their length. After that the web must be thinned. This requires a special radiused grinding wheel and skills that most folks do not have. It should be done on a special drill grinding fixture. That means that only large expensive bits that are worth taking to a professional ahould be sharpened beyond the -10% point.
Cheap split points with thick webs must be resharpened with a split point. This requires a machine with a properly dressed diamond wheel. Better quality split points have enough web thinning to be converted to plain points.
   - guru - Thursday, 04/12/07 21:02:48 EDT
I purchased a very large anvil at an auction recently. It must weigh 250 lbs because it has 25 on the one foot and theirs an emblem on the side which is a circle with an eagle in it. the eagle is the older style ( like what you would see on a liberty silver dollar) the one with two wings and the head turned to the side. I am curious as to what kind it is and where it was made and its value. I would be very interested to know more about it and appreciate that there is a web site that gives me the opportunity to be able to ask these questions. I found your web site on the ask Jeeves web site. Thanks again and I look forward to hearing from you or one of your helpers!
   Jack Rowley - Thursday, 04/12/07 21:12:52 EDT
Jack that sounds like a Fisher-Norris Eagle Anvil. See the link.
   - guru - Thursday, 04/12/07 21:43:00 EDT
Matt,
When you break wrought, you're looking for the part you didn't cut to split lengthwise and kind of peel apart into fibers. Just like a green stick would.
Someone smarter than I am will have to tell whether wrought can *ever* break the way your piece did. But you certainly didn't get a classic wrought-iron break.
   Mike BR - Thursday, 04/12/07 22:12:07 EDT
Wrought.
Pardon me, but the pic looks like a clinker that's been hacksawed a little.
I use the spark test. Fairly straight carrier lines with an occasional break, maybe a dash on the end(s). A few sprigs. No bursting. A little darker color than mild steel. With mild steel, you begin to get some bursting in the spark shower. The catch. You'll need a piece of wrought iron for study and comparison purposes.
   Frank Turley - Thursday, 04/12/07 23:28:46 EDT
FYI: Clean looking Trenton 75 pound anvil in Seattle area on Craig's List... http://seattle.craigslist.org/tac/tls/310983484.html
   Bob Johnson - Friday, 04/13/07 00:32:53 EDT
Hello Guru,
I am to go look at a little giant trip hammer.What is the difference between a trip hammer or power hammer?If so what do I need to be looking at for unfixable problems?Thanks for a great site .I've learned a ton reading the posts and answers!
R.D.
   - Rich - Friday, 04/13/07 07:21:41 EDT
Wrought iron grain.
http://i83.photobucket.com/albums/j291/T-Murch/tt010.jpg
etched
http://i83.photobucket.com/albums/j291/T-Murch/tt-8.jpg
   - TM - Friday, 04/13/07 09:17:32 EDT
Tyler,
I saw those pics of yours posted somewhere else. (Don Fogg's?) But since not all wrought is created equal, I didn't want to assume every WI break will look exactly like that.
Thanks for the input, guys.
   Matt - Friday, 04/13/07 09:30:38 EDT
Ptree, do you need me to bring some RR spikes to TN ?
   daveb - Friday, 04/13/07 09:57:10 EDT
Power Hammer vs. Trip Hammer: The two terms are used interchangeably. However, a trip hammer is most commonly a mechanical hammer and preferably a gravity helve hammer.
First thing to recognize about a Little Giant is that most are at least 75 years old and have been used a LOT.
The second thing is that most people think they can be repaired with a bigger hammer, arc welded or torch. They ARE a machine and some parts were quite precision.
The third thing is that lack of lubrication is a common problem. If it is not dripping with grease and oil then its not properly lubricated. The bearings have no seals, the guides no wipers and even the clutch surfaces get oiled.
Common problems:
Worn or broken dies, loose fitting dies.
Broken dovetails, stuck wedges.
Worn guides. Grab the arms and give it a good shake. The ram should not rattle around in the guides.
Worn bearings. Using a block of wood and a pry bar, pry UP on the ram several inches. You should be able to put upward pressure on the crank wheel. If it lifts noticably then it MAY need rebabbiting. A small amount of slop can be shimmed out IF there are shims remaining.
Worn clutch bearing. This is the most expensive and difficult to repair. There are two types of clutch, a middle clutch and a rear clutch (hanging off the back). The works slides on the drive shaft but should not rattle around. The middle clutches can be in terible condition and still work OK, but the rear clutches become completely uncontrolable if worn.
There are several models of Little Giant but most later hammers came with a "sow block" or anvil cap. This is a seperate piece that is dovetailed to the anvil and if damaged can be replaced. Hammers without this are very expensive to repair if there is a die dovetail problem.
Most small parts of Little Giants are now available and is their only savings grace. New springs can perk up performance and toggle ends smooth the control.
   - guru - Friday, 04/13/07 10:47:36 EDT
Matt, you're welcome.
Ptree, gonna try but can't say for sure.
   quenchcrack - Friday, 04/13/07 11:56:06 EDT
Matt, it looks like the stuff you have could very well be wrought iron.
I have another piece of metal that didn't show much fibrous grain at all after breaking like that, but it has quite a beautiful pattern of different stuffs in it, and it forges as soft as wrought iron. It also has a good bit of copper in it.
   - TM - Friday, 04/13/07 12:53:37 EDT
....so therefore, you're correct that not all wrought is created equal. There are as many variations in it as there are smelters that made it.
   - TM - Friday, 04/13/07 12:56:08 EDT
Tyler,
I'm pretty sure it is WI. Not positive, but the context is an important clue: I found this stuff on a river bank at the site of an old mill that was in operation from the 1740s to the 1920s, when it burned down. Assuming it's from the mill -- which seems very likely -- I think the odds are in my favor.
   Matt - Friday, 04/13/07 14:00:22 EDT
just posted on the other message board - not internet savy
i am trying to "revive" an old peter wright anvil for a friend who wants to learn. Is there a welding rod to rebuild the face of an anvil that will stand up to constant pounding? the one he has cannot be ground smooth and still have a working face.
nathan
   nathan - Friday, 04/13/07 15:02:00 EDT
Nathan, I have seen some pretty rough anvils revived with relatively light grinding. Do not worry about flat. An anvil is NOT a reference surface. In fact a good sway is more useful for straightening than a flat anvil.
For spot welding I know folks that use special manganese tool steel welding rods (one was called super missile rod) along with plain steel rod. These are not hard facing rods but do mix with the high carbon fairly well. This works on spot repairs only and will be a little soft.
If the entire face is to be welded then you use a hard facing rod like a Stoody brand rod. Bill Pieh used to recommend using their build up rod as the others were TOO hard. Do not use any kind of hard facing rod for spot repairs. This results in hard spots that will become high spots and damage hammers.
Avoid welding if at all possible. However, if you must take as much as 1/8" off the surface then that is damaging the anvil as well.
   - guru - Friday, 04/13/07 15:57:08 EDT
I am just starting doing this stuff so I have no clue as to where to look for things, for example walmart
I was wanting to make an aluminum sword like over in the armory section of the web site but I can't find where to buy aluminum blanks. I've been looking for a while and every place I call doesn't even know what I am talking about. So if you could give me some advice about where to find some that would be great.
   - Christopher - Friday, 04/13/07 16:00:00 EDT
Christopher,
If you can't find any locally, you can order it from places like Online Metals: http://onlinemetals.com/merchant.cfm?id=69&step=2 They sell 6061-T6, which is one of the aluminum alloys mentioned in the tutorial you referred to.
   Matt - Friday, 04/13/07 16:09:45 EDT
THANKS!!!
there are several deep gouges (requiring more than 1/8 inch) but the entire face does not need to be rewelded.
kudos!!
this website is a wonderful reference for both experienced smiths and the apprentice. please keep up the good work
   nathan - Friday, 04/13/07 16:39:21 EDT
Nathan; if the gouges are not across the whole face thay do not need to be repaired. All you need is at least *1* area of smooth face to work on and the rest can be pretty rough. Lots less risk of damaging the anvil by not welding on it too.
   Thomas P - Friday, 04/13/07 16:59:52 EDT
Matt, Christoper Etal, Please see the On-line metals link in OUR store. . .
   - guru - Friday, 04/13/07 17:17:59 EDT
I just discovered the iForge area of this site and I am extremely impressed at 1)the idea of having an online real-time forging demo and 2) the quality of the demos being portrayed by these fine gentlemen. Again thankyou for such an AWESOME site where I can learn different blacksmithing techniques from the comfort of my home. This site has to be the best online resource I have found. Thanks again for all your dedication!
   Rhordae - Friday, 04/13/07 17:48:12 EDT
Hey guys, im a hobbyist blacksmith having some trouble finding what tools i need. Right now i've got myself a 3lb hammer and a pair of vice grips... it just doesnt cut it. im having trouble committing to anything on ebay since most of the sellers don't seem to know much about blacksmithing. Centaur forge isnt cheap and their out of stock on most of the things i want. I guess i need help with 2 things really: How much should i be willing to spend on a good tool, and what should no smith be with out, (i know i need a cut off hardie, and some tongs cause pliers dont cut it but im not sure what to get) Right now all i've been doing is simple spirals and curls. but want to start making other things! if anyone has any advice im more than happy to hear it =P. thanks!
-Seb
   Sebastian - Friday, 04/13/07 18:28:30 EDT
oh, and i have a 125# anvil too, nice try smartguys!
   Sebastian - Friday, 04/13/07 18:29:35 EDT
Seb, there are some iForge demos on making tongs. Try the one with the Dempsey Twist. Very simple and they work. You need some flat steel stock to make it with. You can make a rivet out of 1/4" round rod from Lowes. Making your own tools is one of the most satisfying facets of blacksmithing.
   quenchcrack - Friday, 04/13/07 18:35:38 EDT
Sorry about that, Jock! I completely forgot about your link. Very embarrassing! Please feel free to edit me!
   Matt - Friday, 04/13/07 19:28:04 EDT
DaveB, RR spikes would be very nice. The museum just sold the last trowels I had made, and I am out of the good spikes. For a trowel I really like the 5/8" spikes that arnt undercut from the track plate, and I was lucky to find a partial keg a few years ago. All gone now:( Need anything for trade? I have lots of slightly used die springs that make great knives. Also some no carbon steel sheet in small pieces.
   ptree - Friday, 04/13/07 20:11:51 EDT
Guys...
Just read the "Generation X Sword Making or POOF! You're a Swordsmith!" How funny! I was almost in tears. I actually had the benifit of being taught by a sword/knife smith. I worked for him on some of the menial tasks (polishing, rough grinding, rough forging, etc in ecahange for Beer, smokes and knowledge. Looking back, I can see that I came out WAY ahead in the deal! We lost touch over the years. I know this isn't exaclty the right place, but I wanted to publicly thank him for his gift to me. So... S.M. Von Kruger, (AkA Ice) if you every read this page, thank you for your gift of knowledge, It is much appreciated. I would also like to thank you all, esteemed craftsman, for your gifts of knowledge to us Gen Xers et al. I assume most times your help goes unappreciated. I for one appreciate it greatly!
Cheers,
Chris
   Chris Bernard - Friday, 04/13/07 21:35:26 EDT
Chris, thanks. Much of it is tongue in cheek but much is also the truth that many do not want to hear.
   - guru - Friday, 04/13/07 23:17:28 EDT
Tools: When you are poor you need to spend money on tools that help you make tools. The two key items for this in the modern world are an oxy-acetylene welding cutting outfit. A good full size one like a Victor Journeyman set from a reputable dealer and a good 240VAC buzz box. With these two items and an angle grinder you can build almost anything.
Smaller items include a good blacksmiths leg vice and a post , tank or bench to mount it on. A good vice gets used almost as much as the anvil when doing forge work. I like to say vises are my vice as I have numerous types and sizes.
Back to machinery. A good drill press is needed for making tools and producing work. A metal working drill should have a range of 1000 down to 400 RPM. A good small saw will save you a lot of time and grief. Some folks substitute an abrasive chop saw but I dislike the noisy dirty things. Clean square cuts can be applied to work and to making tools and fixtures.
With a good drill press you should plan to purchase a full drill index of top quality HSS drill bits ut to 1/2" or 15mm minimum.
Good tongs can be made or bought. You will not appreciate how inexpensive a $25 pair of tongs are until you make a few that are not as good. DO make tongs. But buying them is efficient use of ones shop time. I have both commercial tonga and tongs I've made for myself. I like and use both. I wish I had time to make all my tongs just to say I did. . .
Our advertisers sell super alloy slitting chisels that cannot be beat. I highly recommend them.
The one thing NOT to do is get stuck on some prehistoric idea of what a "traditional" blacksmith shop is. Blacksmiths are metal workers and they have always sought out the most efficient tools to do their job. In top shops they use power hammers, automated plasma torches and programmable benders along with automatic saws and other machine shop type tools.
The two most important machines in my shop are the Lathe and the Drill press followed by the saw. No matter how much forge work I do these machines are as important as all the rest.
Good luck deciding what to get first. However, finances usually make the decision for most of us.
   - guru - Friday, 04/13/07 23:37:36 EDT
Sebastian: At the the risk of beating my own drum have you even looked at my eBay Store: Poor Boy Blacksmith Tools? Easiest way is to just do a seller search on scharabo, asking for 200 results per page. I think you will find I have some knowledge of blacksmithing and my tools are not only reasonably price, but specifically designed for the beginner/novice smith.
   Ken Scharabok (Poor Boy) - Saturday, 04/14/07 06:30:01 EDT
Where can I find these kinds of files needed to make the aluminum sword
12" Mill file bastard cut
10" Flat smooth cut
8" Flat smooth cut
12" Square bastard cut
10" Flat aluminum cut
8" Half Round aluminum cut
10" Round rough cut
   - Christopher - Saturday, 04/14/07 09:32:01 EDT
Christopher, Almost any major hardware supplier will have all but the special aluminium files. These you will need to get from a machine shop supply. For all odd-ball things that you do not have a local supplier for I use McMaster-Carr (www.mcmaster.com). Sometimes their prices are a little high but they are the most efficient folks I have ever dealt with. If it in their on-line catalog inventory then they really have it and it will be shipped immediately. Any extra cost is worth the convenience and service.
Note that this was just a suggested list and that you will probably just use two or three of these. But files are an investment even though they do wear out. Some files will be replaced often while others will be in use for decades.
File Notes:
Files used for brass and aluminium should not be used on steel. They need and will keep a sharper edge until used on steel.
Handles make files easier to use an let you use more of the file. For large files
