EMBOSSED WORK, p.153, dish, metal, hemispherical, Fig. 99, Cast-iron Block, Raised Forms, Fig. 99, countersunk, raise, raising, hammer, Fig. 100,  Hammer
EMBOSSED WORK p.153 dish. If the operation is continued the metal will become hemispherical in form. The metal used should be soft steel from 1/16 to 3/16 in. thick. Fig. 99. Cast-iron Block Used in Making Raised Forms Fig. 99 shows a block of cast iron which has a hole through it countersunk at the top. This may be used to raise the form on. The method of raising a form is to heat the sheet and hammer it over the hole in the iron block, starting by hammering around the edge with a series of blows until Fig. 100. Hammer Used in Raising
